Capt_RonB's avatar
Capt_RonB
Dometic RML 8555 Refrigerator Door Latch
The door latch (hook/catch/lock/whatchamacallit)on my 3 year old Dometic fridge broke this weekend. The little coil spring that holds the latch hook down appeared to be disconnected.
I was able to use a small pair of forceps (like thin small pliers used for tying fishing flies or holding hooks while you tie on a leader)to extract the spring.
The spring was actually broken and lying there in two pieces. I searched around for a part to no avail but I was able to go to the RVers favorite tool store (Harbor Freight) and for $4 and change I bought a spring assortment that included a spring of approximately the same coil and length.
I used the same small forceps to compress the spring and hold it while I maneuvered it back inside the latch box. I was able to gently pry the cover open enough to get the spring inside and align it over a small metal nub on the top of the metal hook. The small nub locates the spring and keeps it in place.
Once located, I could then release the forceps, let the spring expand and voila! My latch now works as it was intended. Note the new spring in place inside the latch box.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
