Rudyp's avatar
Rudyp
Dometic roof top a/c unit
Good day to all on RV.NET. I recently had a new A/C unit installed on our 5th wheel. We only used it 2-3 times. A couple of weeks ago we tried to use it however it would come on and blowing cold air for @ minutes to 5 minutes; problem is it would stop blowing air completely but the power would stay on.I rechecked the connections. I would turn off the unit at the termostat and wait a few minutes before trying to turn it on. You could hear it click inside the unit and wont turn on and you have to wait awhile longer before turning back on, but then same thing happen's. I called the shop that installed it and they said it could be one of two things that is wrong with it, !. I was told that it could be the Control Box (circuit) box in the AC unit or 2. It could be the thermostat... I asked doesnt the new AC unit come with a control box installed in it? They said no that they took the old one out of the old AC unit and installed it in the new unit... and that it is a seperate part... can some one enlightem me on this? thank you all in advance for the response/help.
Rudy P
  • jdc1, I was plugged in a 50amp.. Only had the one ac unit on ...
  • jdc1's avatar
    jdc1
    Explorer II
    Are you at home? Plugged into a standard wall outlet? How many amps is that wall outlet actually putting out?
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
