aurcor's avatar
aurcor
dometic thermo prob
Hello, new to RV life and this forum.
Recently my wife complains that our thermostat doesn't shut off properly. It did keep the heat on one time until we were cooking (way above set temp). [ dometic duo therm comfort control center with phone plug connection]
I finally bought an inexpensive replacement on Amazon. [White Rodgers 1C20-101 Economy 24 Volt/Millivolt Heat Thermostat] And thought it should work for our heating/cooling needs.
Last night I traded it out by cutting the wire with the RJ-8(ish) plug and connected the wires to the new thermostat, following the chart provided by new thermo mfg.
It did not work.
So I re-connected the phone plug to the original cable and inserted back into our Dometic CCC thermostat, and nothing. No backlight screen or anything.
Note: while I was trying to connect the new analog thermo the Red and Green wires touched long enough to smolder and melt some insulation.
I'm willing to take common 'you did what?'s' in replies in my ignorance, but don't forget to provide a possible solution.
thanks in advance
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 13, 2025
