dougrainer
Mar 07, 2022Nomad
If you are talking about the 2 red wires with spades on the board? 1 Wire is smaller gauge than the other?. That is the connection for the Fan motor. It does not really supply voltage to activate the board and LED. The side board quick connect is what powers the board. The BLUE wire should have 12 volts when the Tstat closes. Check for that and then see if the LED light blinks or comes on. Doug
