I put a 3.2 Igloo (from London Drugs) in the truck camper and it all worked, but that was with a bigger battery bank. See my post here on that. (BTW a slightly bigger 3.3 had a better fridge layout for putting things, but wouldn't fit in the TC--was an inch too tall)
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28391918/gotomsg/28391985.cfm#28391985You can do that but IMO you will need more battery or with just the two, then as well as the solar, be prepared to run the gen for an hour or two daily (running a converter that will do the 14.4v or so fast charge--if all it does is 13.6, you need something else.)
Here is my initial testing results post
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28286028.cfm
