dougrainer
May 05, 2018Nomad
y22man wrote:dougrainer wrote:
1. Adding a fan will NOT help the freezer at all
2. Norcold 4 door refers NEVER need an additional fan inside for the cooling fins
3. IF you have operational issues, then odds are the INSTALL, the area behind the refer is NOT correct for flow thru ventilation up the cooling coils. As another stated, the OEM's rarely install the refers in a cabinet that meets minimum Norcold install standards.
4. IS this refer in a slide room? Doug
Yes it is a slide. I think he was saying install a fan on the outside by the heat exchange fins. I could be wrong.
Jay
The Norcold 4 doors HAVE external fans(2) already. What your problem is, the OEM did not install the baffling correctly to get all the HOT air out the top vent. When you have a RV refer in a slide, Installing a 3rd fan at the top blowing straight out the upper door will INDEED make the refer operate better and at its peak. I also assume you have not added screening or bug screens on the exterior vent doors of the refer wall? Doug
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
