pbitschura
Apr 02, 2016Explorer
corvettekent wrote:Thank you.pbitschura wrote:
So, off a full battery, I wouldn't have enough amps to run the microwave for 5 minutes?I have an on board inverter.
My 4k Onan can do it directly. Obviously a different situation. But if the answer to the first question is no, the question is mute. And the point of my question is, would a 40 watt solar system allow me to charge the battery and use the systems I described, granted I have a generator. Or would this be a waste of money?
Use your 4K Onan to run the microwave and coffee maker then get a 120 watt solar system and a pair of golf cart batteries along with LED lights and you will be able to watch TV, use your lights, run the water pump and the furnace.
