MEXICOWANDERER
Apr 22, 2019Explorer
The QUACKS had me on an O2 concentrator that sucked 520 watts at 1.2 liters. Is a 12 volt concentrator -The New Miracle-? Flapping and whirring through the night?
I just cannot imagine a 12 volt concentrator. Would be like a 12 volt microwave.
The humidifier uses four times the power of the CPAP blower. So that's a factor.
Methinks you are on the wrong trail. Two 24's will allow around 85 amp hours total With standard gizmos online after dark you will be taxing group24 batteries to the max. I suspect the O2 unit is 120vac. A pipe dream.
Might want to start thinking about a 1500 watt generator that can run 8 hours.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
