Ivylog
Nov 14, 2013Explorer III
Not the answer you wanted, but the easiest is to use two 5 gallon buckets moving the first one when only half full so it's easy to slide the second one into postion. With the half full one under the filter, punch a hole in the bottom of the filter and come back in an hour when it and the engine are finished draining..
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
