rv2go
Nov 14, 2013Explorer II
I use a plastic tote that is large enough. I then place a large garbage bag in the tote. I make sure that the full tote will be on a surface smooth enough that I can pull it from under the MH. I then use a small 12volt pump to pump the oil back into the gallon containers. When thru, I remove the oily garbage bag and the tote is as clean as new.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
