l001952119
Nov 14, 2013Explorer
lanerd wrote:
My Cummins ILS holds 28 quarts of oil (7 gallons). The largest container I can find that is used to drain the old oil into is only 5 gallons. What do others use so that you don't have to use two containers?
Ron
I assume you mean draining the oil directly from the crankcase into a container? If so, NAPA has a 56 quart oil drain pan with a spout for emptying. Must be ordered from catalog. My prior truck had a 38 quart capacity. After draining into the 56 qt. pan, I poured the oil, via a large truck funnel, into two five gallon gas cans and emptied them at Wal-Mart. They have a five gallon limit, but once they know you, ten gallons can usually be dumped!
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
