pkunk
Nov 14, 2013Explorer
Too Tall wrote:
Do MH's ever have a line off the bottom of the pan? Engines in boats have them so you can use a 12vdc or AC pump to drain and fill. Makes life easy.
Not from the factory, but a Fumoto valve can be installed. I put mine on with a full crankcase bu using a shopvac to hold the oil up while replacing drain plug with Fumoto. The Fumoto with the nipple that you can put a clear hose on make it easy to drain into gal. containers.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
