dougrainer
Jul 24, 2020Nomad
1. It does not drain because the OEM installed a check valve in the Inlet of the water heater
2. ALWAYS remove the WH drain plug to drain the WH. This keeps it from sticking(Suburban WH) and is a lot quicker. Besides, you do NOT want the usual Mineral debris back feeding into the fresh water lines and Faucet valves. There is almost always mineral debris in the HW tank.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
