Filtering Tap Water
Many but not all available home water filters remove Cryptosporidium. Some filter designs are more suitable for removal of Cryptosporidium than others. Filters that have the words “reverse osmosis” on the label protect against Cryptosporidium. Some other types of filters that function by micro-straining also work. Look for a filter that has a pore size of 1 micron or less. This will remove microbes 1 micron or greater in diameter (Cryptosporidium, Giardia). There are two types of these filters — “absolute 1 micron” filters and “nominal 1 micron” filters but not all filters that are supposed to remove objects 1 micron or larger from water are the same. The absolute 1 micron filter will more consistently remove Cryptosporidium than a nominal filter. Some nominal 1 micron filters will allow 20% to 30% of 1 micron particles (like Cryptosporidium) to pass through.
Filter manufacturers may pay to have their filters tested to see if they remove Cryptosporidium or Giardia. Filters that have been tested and certified should have wording on their labels indicating they have been listed and labeled to NSF/ANSI Standard 53 or Standard 58 for cyst removal or cyst reduction by an ANSI-accredited certification organization. To find out if a particular filter is certified to remove Cryptosporidium, you can look for “NSF 53” or “NSF 58” plus the words “cyst reduction” or “cyst removal” on the product label information. If you chose to use a non-certified product, select those technologies more likely to reduce Cryptosporidium, including filters with reverse osmosis and those that have an absolute pore size of 1 micron or smaller.
Because filter testing is expensive and voluntary, some filters that may work against Cryptosporidium may not have been tested. If you chose to use a product not labeled “NSF 53” or “NSF 58”, select those technologies more likely to reduce Cryptosporidium, including filters with reverse osmosis and those that have an absolute pore size of 1 micron or smaller.
Filters designed to remove Crypto (any of the four messages below on a package label indicate that the filter should be able to remove Crypto)
Reverse osmosis (with or without NSF 53 or NSF 58 labeling)
Absolute pore size of 1 micron or smaller (with or without NSF 53 or NSF 58 labeling)
Tested and certified to NSF/ANSI Standard 53 or NSF/ANSI Standard 58 for cyst removal
Tested and certified to NSF/ANSI Standard 53 or NSF/ANSI Standard 58 for cyst reduction
Filters labeled only with these words may NOT be designed to remove Crypto
Nominal pore size of 1 micron or smaller
One micron filter
Effective against Giardia
Effective against parasites
Carbon filter
Water purifier
EPA approved (Caution: EPA does not approve or test filters)
EPA registered (Caution: EPA does not register filters based on their ability to remove Cryptosporidium)
Activated carbon
Removes chlorine
Ultraviolet light
Pentiodide resins
Water softener
Chlorinated
(U.S Center For Disease Control)
