swimmer_spe wrote:
That sounds like a good idea.
all that will tell you is how that one small sample tests at that point of time. and of course only for the contaminants that are tested for, since that will be somewhat limited. also required would be seasonal sampling to determine variance there. are there any farm fields that are periodically sprayed with pesticides where run off would occur?
it is obvious that you intend to do this regardless of what is said, so wrap yourself with bubble wrap and enjoy yourself. there is a difference between a troll and an intelligent responder giving meaningful advice, regardless whether you want to listen or not.
bumpy
