rk911 wrote:
Eyeland wrote:
Been fulltiming for 9 yrs and been using the white drinking water hose that most of us use. What a pain!! Just try to roll it up to store away. You know the problem.. Tried the type hose that extends with the psi of the water and then shrinks after the water is turned off. Worked well until blow out in a month. You guys got any suggestions for Drinking water hose?
sure. I have two 10-ft lengths of white drinking water hose and another 25-ft length on a hand-held reel. 8 times outta 10 I can hook up to the fresh water spigot with a single 10-ft length. if that's not enough then I add the second 10-ft length. only rarely do I need the 25-ft reel. but when I do the hose rolls up quite easily on the reel.
basically what I do. did buy a long non-kink hose also.
bumpy
