jensenst's avatar
jensenst
dry camping
I need to dry camp one night in Jasper Nat Park. Only want to keep the refrigerator running for one day. Will the battery last 18hrs. Need advice
  • I need to dry camp one night in Jasper Nat Park. Only want to keep the refrigerator running for one day. Will the battery last 18hrs. Need advice
    maillemaker wrote:
    Is your refrigerator running off of propane or 12V? If propane, the system uses only a tiny bit of electricity to keep the gas flowing. It will run for days on battery in that case.
    Not if that fridge's climate control heating element has not been turned off, it won't. :R The best "advice", which the OP asked for, is to make sure this element is off whenever running on battery power.
  • No answer is going to be correct until the OP returns to identify his/her fridge.
  • Run the refer on propane. It is not that warm in Alberta. Everything will be fine it you do not run your furnace too much.
  • Not if that fridge's climate control heating element has not been turned off, it won't.
    You already mentioned that on page 1, so I didn't feel the need to be pedantic about that.
    Steve
    His profile shows a 2012 Flagstaff Micro-lite, so it's a 2-way fridge.
    Unless it was switched out with a residential at some point.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
