Redterpos3
Mar 27, 2015Explorer
Dual 30 amp rv's?
Was doing some "window" shopping on Camping World site, and saw a dogbone for dual 30 amp to a single 50 amp receptacle. Are there actually RV's that have 2 30 amp hookups??
greenrvgreen wrote:I installed an auxillary 20A circuit in my 50A rig. It can plug into the engine block heater circuit which is a dedicated 20A circuit or it can be plugged into a CG pedestal when the CG is 30A.
I have a 30-amp trailer and I added an auxillary 20-amp inlet, along with a discrete run of wire feeding 20-amp GFCI outlets placed near to major items that I may want to plug in.
I use this when my main source of shore power is rather weaker than the 30-amp capacity, and/or I wish to exceed the available capacity, even at a full 30 amps. I can feed the aux inlet from a generator or from a second, separate shore power source.
I don't use this aux inlet very often, but when I need it it really saves the day. Even if my next RV has a 50 amp service, I will still add an aux inlet and power bus, just to have the option of a secondary (concurrent) power source.
