theoldwizard1
Jan 29, 2020Explorer II
unsavory wrote:
The problem I am having, is that I am not able to get these Odyssey batteries to charge properly in the Jeep Wrangler, because it has a very funky "smart charging system", that varies the charging voltage as you are driving to "save gas mileage".
Yep ! Pretty standard on almost every vehicle from about 2005.
unsavory wrote:
All of the DC to DC chargers seem to want the starter battery separated from the accessory battery, as they already have an isolator built in.
Follow the instructions ! What you are missing is that theses DC-DC chargers actually boost the voltage going to the second battery so that it get the correct voltage no matter what is being sent to the starting battery.
unsavory wrote:
The other option I am exploring, is just disabling the smart charging in the Jeep by disconnecting the Intelligent Battery Sensor. But this causes the alternator to put out a constant 14.5v, and I'm worried this will actually OVERCHARGE my batteries... but I'm not sure?
DON'T DO IT ! The computer module is very smart and trying to trick it, is not a good idea.
If the charging characteristics of the Odyssey AGM batteries are that different compared to a normal "flooded" lead acid, re-install a plain battery as your starting battery.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
