mbopp's avatar
mbopp
Dual to Single Propane Regulator
It appears my auto-switching regulator leaves a few pounds of propane in the "empty" tank. I have a single tank RV regulator from a previous project and installed it in place of the auto-switching one.
Are there any issues with "T"-ing the tanks together and running the input line to the regulator? Or should I just unscrew the tank connector and switch it manually? I don't plan to run with both tanks "on" (good way to run out of propane unexpectedly.)
  • Chris Bryant wrote:
    It will go red, simply because the tank pressure is below the set point, but it should flow until empty..
    +1 this is about what mine does.
    OP, as long as you only have one open at a time then you may as well use a single input regulator.
  • It will go red, simply because the tank pressure is below the set point, but it should flow until empty..
  • Yes, it's a 2-stage regulator from my old pop-up I converted to dual tanks.
    Nope, with the spare tank valve closed the indicator window goes to red (no gas) with several pounds left. DB has the same gripe on his toy hauler.
    Now off to the hardware store.....
  • If you simply don't turn on both cylinders, the auto regulator will use all of the LP. It simply switches when tank pressure gets below ~20-30 psi, but only if the aux cylinder has above that pressure.
    I assume your "new" regulator is a 2 stage- a single stage is not adequate for RV use.
  • I’ll trade the convenience of the auto switch and a few pounds left in the tank for the inconvenience of running out of gas when dinner is in the oven baking or roasting or the wx is cold and stormy and the furnace quits in the middle of the night. YMMV.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
