joelyn
Jul 06, 2015Explorer
path1 wrote:
My answer is...it depends on your plumbing at your dump valve that you have right now.
It worked OK but not great on a TT we had. But on our 5th wheel it didn't work so good. My reasoning was because of the way the plumbing was set up on each.
The trailer pipe was a straight in shot and the water went inside and stuff was able to get flushed out after awhile.
But on the 5th wheel the pipe came down maybe 6 inches before it went inside tank. When using the flush valve the water pressure wasn't big enough to over come the 6 inch rise.
Kind of makes sense. thanks. We have a TT and will have to check out the angle of the pipe. TY
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
