Thunder_Mountai
Nov 22, 2015Explorer II
Duh - Problem with new Suburban furnace not Atwood
Had a senior moment yesterday. New Winnie has Suburban furnace not Atwood! All of the problems below apply to the Suburban furnace.
Just took delivery on new Winnie. Front furnace worked fine during PDI on Thursday. No heat now. Fan running, blowing cold air. Can't hear tick-tick-tick of igniter. Can smell hint of propane at exhaust when I try to light. So, I know it's getting gas. Intake and exhaust not blocked. Propane tank at 88%. Propane lines have been bleed of air. Stove works as does rear furnace.
It's obviously under warranty, but thought there might be a quick fix. I suspect control board, but is there a fuse to check? Other ideas?
I assume there are probably LED codes to read as with the Atwood. Thanks for the responses in advance. Will be on the road and possibly not able to reply for the next 7-8 hours.
