Arcticold
Mar 05, 2014Explorer
BobsYourUncle wrote:
OK, I have never had to consider a full fridge replacement before.
My fridge has bitten the big green weenie and decided to roll over and die.... Seems that Bob expected it to survive in -33C with wind chills of -40's.....
It didn't.
I bought this rig last May, in favor of replacing my old rotting Sportsmen. Another story there....
Anyhow, I'm working in stupidly cold freezing temperatures and my fridge is toast. Or so it seems.
I could buy an Amish cooling unit and fix the thing, but I really don't like this fridge. Dometic Americana. No model number on it but I think it is RM 2652.
I have never liked this thing, it has no temperature control whatsoever. It is on, or it is off. Period, no more. I hate it. Eyebrow panel - on/off/ auto/ gas. Thats it.
Anyhow, looks like I have to put a new one in.
Several different brands out there, Dometic, Norcold and a few others.
Bewilderment sets in, as I have never needed to compare brands before. But I need to know. If I'm going to buy a fridge, may as well get something better than this thing.
Is this the old Ford vs Chevy vs Dodge deal?
Or is one brand of RV fridge better than the other?
I am looking at options for fridge replacement. I don't have 2G to shell out but need a fridge.
I salvaged most of my stuff from the freezer, cooked it all up and put it in my pickup where it promptly froze, but ate like an oink the past 2 nights trying not to throw stuff out. Think I'll barf if I stuff any more in the piehole.... I hate wasting food.
And no, I am not interested in putting a 110 only unit in. I boondock a lot and I need a proper RV fridge.
Is there any difference in quality of Norcold, Dometic and others?
If your RM2652 cooling unit has leaked, you will more then likely be able to see the yellow/green residue around the burner area on the rear of the fridge. Looking through the side vent on the rv it is on the right hand side just below the duct work. In most cases it is visually obvious when the weld lets go due to the yellow/green staining. You mentioned that it is extremely cold out. Your cooling unit will not operate when it is extremely cold out. This is because the ammonia in you cooling unit must reach a certain temperature to boil. As previously noted a light bulb in the rear of the fridge does help. Also if that alone does not work, you can place a piece of insulation (Non combustible) over a portion of the rear vent to help hold the heat in. This will also help, but remember to remove it when the outside temperature starts to rise. Also if you do not like how your refrigerator does not have a controllable thermostat, there is an option. It is a thermistor adjuster made by Dinosaur Electronics. It is a product that allows you to adjust the temperature of the fixed temperature Dometic refrigerators such as your. It will simply hook up to your existing thermistor. Your local dealer will be able to order it for you.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
