Monkeyrun
Apr 19, 2016Explorer
Thank you! I would bet on stuck, they were never used much and the few times I have test run them I had to turn both units off/on several times to get them to switch to cooling. I wonder if the ole hammer tap would un-stick it? One unit is running full time to keep up with the heat now but holding its own. At any rate, I can make the final repair, now seeing what the part looks like (thanks Chris).
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
