Monkeyrun
Apr 20, 2016Explorer
It seems they tend to be stuck on the heat function when I attempt to start them, however, I will pay closer attention in the future. Other than our trip last fall, the only use they have seen since I purchased the rig has been a few cycle runs to keep the seals in shape. The units were used for only about a year prior to me buying this coach, not under warranty I suspect, but I do have the paperwork and dealer info. Again, thank you all for the extremely useful information. Once I knew what to go after, I used the control box to switch from off to cool without allowing the unit to start. After a few tries, I heard a definite difference in the sound from the unit above me, at that point I allowed it to continue to start the compressor and bingo, she had switched to cooling. Since that time, both units have cycled off and on frequently without issue.....so far.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
