dougrainer
Oct 17, 2014Nomad
The upper control board has a relay that supplies power to the Compressor. Then the Start Capacitor kicks in. I doubt your control board is the problem. Either the compressor is locked up or the Start Capacitor is bad. You do NOT have to purchase a NEW tstat if you buy a new Penguin. You just purchase a 12 button to 5 button change kit to install on the new Penguin to operate with your existing Tstat. This is best if you have 2 roof top units because you will have to replace the 2nd unit completely if you buy the new Penguin and the new 12 button tstat. 12 and 5 button control boards are not compatible. If you do NOT have 2 roof top units and just the One unit, then buy the new 12 button tstat as the change out kit and the new Tstat are about the same price. Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
