CJ_T
Jul 04, 2014Explorer
Chris,
Thanks for the advice. Do you just go about breaking off pieces of the fan blade assembly, or maybe take a Dremel and cut/grind a slot in the hub ?
Also, do the replacement blades come with a new screw clamp to hold the blade onto the shaft ?
Do you need to sand the shaft to remove the rust before putting the new blade on ?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
