Rick_Jay
Oct 21, 2013Explorer II
iluvwdw54 wrote:
During our annual winterizing routine, our water pump worked fine for shower and toilet and while pumping to the bathroom sink, it just stopped. Our coach battery is bad, stopped putting the step out, so we assumed that is completely dead and that is why the water pump stopped. Then we start the engine and the entire RV will not start! We have had this issue in the past but it ran fine all summer, no issues. Does a bad step/coach battery effect power to the fuel pump too?
Hi, and welcome to the forums. :)
It might be more helpful if you could give us the year, make & model of your RV. But lacking that, I'll do what I can.
I think I agree with you that your coach battery is dead, which is why the steps and water pump do not work. If you're plugged into shore power, you should have some DC power from the converter. However, if the converter is not working, then the coach battery won't charge.
"Then we start the engine and the entire RV will not start!" Did it start or not? Did you mean "Tried to start the engine....?"
If it didn't start, then most likely the chassis battery is dead as well. There should be an isolator between the two batteries that prevents them from both discharging simultaneously. However, if the isolator isn't working (or isn't there), then the batteries are most likely connected together in parallel and both will run down. Normally, a dead coach battery won't keep the chassis engine from starting. And vice versa, a dead chassis battery should not run down the coach battery. Most rigs (I thought) have an emergency start switch which will "parallel" both batteries so if one battery is low, you can use the other to "jump it" to get started. Again, if that circuit isn't working properly, or someone rewired things, the batteries might always be in a parallel connection with no isolation.
If the chassis battery runs down, that will keep the fuel pump (assuming it's an electric fuel pump) from operating, as well as the starter and usually any electronic engine control module(s). The obvious result is that the engine won't start. But a low coach battery should NOT keep the chassis fuel pump from running UNLESS someone did some rewiring from the factory configuration.
Like MEXICOWANDERER asked, do you have any tools & know-how to trouble-shoot the systems?
At the very least, I would think a decent battery charger would be helpful for getting a charge into the batteries. Before charging the batteries, check to make sure they have the proper level of water in them. If the cells are low/empty on water, the batteries won't hold a charge.
Good Luck,
~Rick
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
