iluvwdw54
Oct 21, 2013Explorer
This is a 2000 Coachmen Leprechaun. The regular battery is relatively new, it turns over fine, tries to start with starter fluid but won't hold the start. It seems when we get down to a quarter tank, we have this problem. We checked the fuel shut off under the dash, that is intact as it should be. the coach battery is from 2006 and we should have changed it when we de-winterized the RV and did not. I just find it weird that the water pump stopped and then the motor will not start. It started fine when we took it out of storage to bring over home here. We assumed the water pump problem was the coach battery but wasn't sure if that could affect the fuel pump or not. Just hoping it is not the fuel pump itself.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
