RJsfishin wrote:
David R wrote:
Small engines are not built for E-85 and likely to have problems due to it. There is a great deal of information available on the subject.
Beware, there is a lot of false information on the subject too !
Correct, but let's see what Honda says...
Honda small engine fuel recommendations"
Can I use E85 in my Honda Engine?
E85 contains 85% ethanol and must not be used in Honda engines.Using fuels with percentages of ethanol or methanol higher than 10% (E10) will cause starting and/or performance problems. It can also damage metal, rubber, and plastic fuel system components that are not covered under the Distributor’s Limited Warranty. "
