dougrainer
Jun 05, 2016Nomad
gpascazio wrote:
bphusmc,
Did you ever take a photo of your fix. What kind of hard pipe did you use? With our camper it is the opposite of yours the refrigerator works fine when it is closed and works poorly in the fully open position. I am afraid that if I use the wrong fix the kink is just going to move somewhere else.
You can use a PVC pipe that is slightly larger than the hose at the kink. Cut the PVC in half length wise and then use hose clamps to secure over the existing kink. You may have to reroute the hose system to prevent a kink in the area it happened. Doug
