pianotuna
Sep 06, 2013Nomad III
Hi,
Although the kill-a-watt only measures AC, you can "cheat" and use it to measure DC by disconnecting the battery and powering the RV directly from the converter.
If you know the power factor of the converter (Progressive Dynamics is 0.7) you can change the watts into DC amps by dividing by 12 (or 13.6) depending on the converter output.
Don't do this with one of the older converters that requires a battery for stabilizing the DC voltage.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
