Big_Katuna
Sep 07, 2013Explorer II
Use the Kila a watt to determine your AC amperage, then you just move the decimal over to get DC amps. One A at 120 volt is 10 A at 12.
Most meters only will measure a few amps in series. Potentiooly dangerous for measuring AC current.
There are lists on the net that give typical amp draw for most appliances.
Cool thing about the Kilawatt is you can leave something plugged in for 24 hours and it records total watts used so it catches the entire profile, not just one moment in time.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
