Golden_HVAC
Sep 06, 2013Explorer
Hi,
I have a E-Meter, it is about $450, so probably way out of your budget for something to buy for the RV. Even I did not want to buy it, would have rather bought a 75 watt solar panel at the time, it would add energy, not measure it.
Anyway the E-meter tells me a lot. It carefully measures the amp hours going into and out of the battery bank. How does this help you? Well I can tell you that the refrigerator, CO meter an propane leak detectors use a total of about 35 amp hours per day, about what one of my 120 watt solar panels will put out in a day. Each light bulb is about 1.1 amps, while I changed to 24 LED panels, that are only 0.1 amps each, and two of the panels are brighter than one of the old light bulbs. I put in 4 of the LED panels in the porch light, it is really bright now, and only 0.4 amps, about 1/3 of the old light.
Your furnace is another large load. It can draw 5 - 8 amps per hour, though you only normally run it about 2 hours per day, unless it is really cold out. I have a Olympic Catalytic heater, no 12 volt power at all, but I need to leave a roof vent and window open all the time (just like while cooking).
Your charger should be putting out about 35 amps per hour to a pair of batteries, in the first hour. The second hour is going to be less, say 25 - 30 AH, depending on how full the battery is getting. 3 and 4th hours, probably less than 20 AH per hour,and it will taper to even less power per hour after that. It is better to run the generator for about 1 hour early morning and later in the day, it gives the most amps per hour that way
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
