subcamper
Sep 07, 2013Explorer II
bdosborn wrote:RLGetman wrote:
I would like to do some boondocking in Oct. How can I determine battery drain when I turn on a device, like a TV, amp, etc... while boondocking? Looking for an easy/cheap method to accomplish. Thanks
Turnigy meter, $23.
Spec.
Operating voltage: 4.8~60V (0V with optional auxiliary battery)
Measures;
0~130A, resolution 0.01A
0~60V, resolution 0.01V
0~6554W, resolution 0.1W
0~65Ah, resolution 0.001Ah
0~6554Wh, resolution 0.1Wh
Screen: 16x2, backlit LCD display
Weight: 82g
Turnigy Meter
Bruce
This looks like a good deal for a meter that is probably accurate enough for RV use. I might pick one up.
Just remember, resolution does not equal accuracy. Resolution is just the minimum change the display will show. So if the resolution is 0.1 amps, the display will change in 0.1 amp increments. The above specs do not say anything about actual accuracy. Although I suspect the accuracy will be fine for our use.
Steve
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
