John_Joey
May 15, 2014Explorer
danly wrote:
Its a brass fitting with a drain cock on it, which is stripped.
Without seeing what you got, I'll make a few statements hoping they will help.
First, that is not a standard setup and I would discard it. If it is an atwood I would go back to a plastic plug, or if suburban then a zinc rod.
Second, brass doesn't corrode so I'm guessing it's the petcock that is steel and a mess. If that is the case leave the petcock alone and just pull the brass plug and throw the whole thing away. Go back to the OEM for your hot water heater.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
