- midnightsadieExplorer IItake wide blade screw driver heat and push in , some times you just take a sharp chisel and break it out ,be careful don,t hit the threads.when puting new one in rap threads with teflon tape and don,t over tighten.
- Road_RunnersExplorerIs the drain plug broken or is it just stuck and won't come out? If it is stuck and won't come out it will usually break loose if you use a long handled breaker bar. I have a length of pipe that fits over my ratchet handle. Works every time.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
