Bill_Satellite's avatar
Bill_Satellite
Explorer II
Oct 03, 2017
Easy way to take 12V input and create 24V output
My coach has some 24V fans running with 12V power and I would like get them the full 24V they are rated at as there is also a speed controller I can use to control the speed and noise (Country Coach set it up this way to keep the sound down).
I have seen some setups online but don't really quite get it. I will have 1 12V input with a good size wire and it would need to output 24V (18-24V) so I can get some additional "blow" from the fans. The output will go to 3 squirrel cage type fans in my diesel heat (Webasto) fans. I have good access to the input and output wiring so if I can find the right device it should be pretty simple to setup. It's also in a fairly open cabinet so heat dissipation should not be an issue if these things create heat.
  • Unavailable at the moment on AMAZON. I use these critters and they have proven reliable
    BUT\
    The CURRENT control network is near useless.\
    Which would not be an issue in your case
    DROK
    DROK DC/DC Boost Converter 12-60V to 12-80V Step-up Voltage Regulator 600W Auto Power Supply Transformer Adjustable Output Volt Controller Stabilizer Board Laptop Motor
    3.3 out of 5 stars 16 customer reviews
    | 5 answered questions
    Currently unavailable.
    We don't know when or if this item will be back in stock.
    Specifications for this item
    Part Number 090499
    Measurement System US
    UPC 619397028094
    Brand Name DROK
    EAN 0619397028094
    Model Number 090499
    Number of Items 1
    UNSPSC Code 39121006
  • Bill, don't know if you have done an Amazon search yet but mine turned up several posibilities depending on the max current you require.
