Strador's avatar
Strador
Easystart functionality built into RV AC units?
Pardon my greenness. I am 100% a newbie when it comes to RV’ing. I have a 33 ft class C, 30 amp, that has a single AC unit. The fan in the bedroom is pre-wired for a second unit, so it should be easy to install, I live in Arizona so the second unit would be nice to have.
Obviously, the issue is power, or more specifically startup power. I have been working with the math and 30amps is enough to run 2 AC units once you get past that huge initial startup draw. In doing some reading it would appear it should work just fine using products like easystart or softstart.
I guess my question is, why are RV AC manufactures not including easystart/software capabilities directly into the unit? Or, are there actually units out there that does this and I can’t find them? It would seem like this would be a no brainier especially with the RV power limitation?
    That's one of those 'looks good on paper' things, but in reality you're likely to burn up your plug.
    I have a 50 amp fifth wheel so I think it is different, but my understanding in the 30 amp motorhomes is they run on one thermostat (mine has two separate thermostats). When one thermostat controls both, then I think it ensures that they do not try to start at the same time, which is how you can get away with 30 amps for two units. As stated, keep an eye on the voltage and make sure you do not run too much. Tripping the breaker is not a big deal, you can just reset it, but if the voltage drops too low bad things happen to the AC units.
  • Because it costs money and generally they aren't needed. A 30 amp outlet is plenty to start a single air/con and a 50amp outlet is plenty to start 2 air/con units (or even 3 units).
    It's really only when you try to use an undersized generator or overload a 30amp outlet, where these units really become useful.
    Also running 2 air/con units is pretty marginal on a 30amp outlet. Keep in mind, 30amps is the nominal rating. Continuous output is limited to 80% or 24amps. You see a lot of burnt up 30amp plugs from people who think they have 30amps, so they are going to use 30 amps.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
