NinerBikes
Oct 20, 2014Explorer
Snowman9000 wrote:greenrvgreen wrote:
jr, for maximum value start with a cheap PWM controller and nominal 12V (~18V) panels. Make them somehow portable, even if only to lean against your RV. Run these for a year and then figure out what the ideal system would be, and spend your big money and drill holes for that.
I wish I'd done this, I'd be $1500 richer right now. My Kyocera 315 panels and my FlexMax 80 are nothing but museum pieces, while my Renogy portables and cheap PWM actually get the job done. If I buy enough Renogy panels to bump the voltage, maybe I can get some use out of the Flexmax. But until then I've basically pineconed myself.
Consider:
--"Cost per amp" of panel at 12v PWM. Now SUBTRACT the cost savings of PWM vs MPPT.
--"Amps per square foot" of panel at 12v PWM. These are "actual amps" vs "potential amp gains" of MPPT, subject to heat loss, light clouds, etc etc etc.
Dont spend $500 additional on an MPPT (it really IS MPPT) controller than cannot possibly harvest an extra $500 worth of power over its service life.
I'm happy I started with a 100w portable setup. People say there are too many compromises with portables. So yes, they require handling, and maybe a locking cable depending on where you are. But on the plus side, you can often park in the shade while putting the panel in the sun, harvest a lot of watts, with minimal installation hassles, and cheaply. All of those good features are compromised on roof mount panels. :) :) :)
Someone who travels around a lot should have roof panels, no doubt. But the typical person who camps someplace for a week or so, with two batteries, LED lights, and commonsense use of energy, can get a lot or maybe all of his needs from 100 to 200 watts on the ground.
Now I'm going to add roof panels as the next step. But since I like shade, I expect to have to supplement with the portables when we camp in the summer.
As easy or as hard as you want to make it.
Knowing where you are at, for amps replaced, with this $16 device, in line.
