BFL13
Nov 07, 2014Explorer II
jrnymn7 wrote:
Will 0.12 Voc make that much of a difference though?
And if I parallel two 12v panels, does the Voc double?
The usual story with solar controllers is if you go over the Voc limit by even a little tiny bit it will instantly fry it. Can't say if it is really that dicey, but they also warn to allow for higher Voc in the cold so it must be sensitive.
If that second question has not been edited out by the time I post this--:) No it doubles in series. Amps double in parallel.
The Solar30 will do pretty much the same as the Eco-W with a pair of 12s. The Eco-W is really for one big 24v (to 250w)not two 12s in series with that 42-45 limit.
