jrnymn7
Nov 07, 2014Explorer
"Whatever controller you get, make sure it has adjustable high set point. IMO ignore temp comp except for long term storage battery Float. While camping you can play with the Vabs if especially hot or cold out."
Yeah, I was thinking I could make any temp adjustments manually, throughout the year, just like with my charger.
If I understand correctly, that Eco-W 20a mppt has a set point adjustment of 13-15.5v... except they call it "Constant voltage (Over charge) voltage".
And I'm guessing "max discharge current" only applies to a direct load off the controller, not from the bank?
