DSchmidt_2000
May 19, 2013Explorer
Did some testing today. (sorry for the data not being aligned- don't know how to post formatted text).
Setup:
45W 12V Solar Blvd panel with these specs
Maximum Power Voltage (Vmp): 18.0V
Maximum Power Current (Imp): 2.5A
Short Circuit Current (Isc): 2.73A
12V 35AH SLA battery which I depleted about 75% yesterday
Watt's-up meter in-line with the battery to measure current INTO the battery, battery voltage, and watts into battery.
DMM to measure the solar panel's voltage at the input of the MPPT controller.
I have Deans Connectors between the watts-up and the MPPT controller and between the solar panel and the MPPT controller so I can easily unplug things and make changes.
Testing: What I did was measure the current going into the battery if the MPPT controller was "in-the-loop", and then connected the solar panel directly to the battery. With the Deans connectors, I could do this switch around in seconds.
Here are the measurements in order they were taken (if no measurement listed - then I forgot to write it down)
The battery voltage and watts were from the Watt's-up meter - it has uncertainty in its measurements hence the watts reported are not exactly that calculated just doing the math.
I'm a bit disappointed to not have a much greater charging amps (only ~ 0.1A greater) given the delta between the battery and the panel is about 4V. Thinking that I may just be so low in power that I'm not in a high efficiency zone for this MPPT controller.
Putting my ear to the MPPT controller, I hear a regular 'ticking' noise. Will at some point drag out my digital scope and take some measurements to see what is going on.
Setup:
With the MPPT "in-the-loop"
Solar V Batt A Batt V Watts
16.76 3.08 12.51
17.00 3.05 12.51
Solar direct to battery
2.89 12.50V 35.5
17.05 3.02 12.51 37.4
16.94 3.07 12.52 37.1
2.93 12.51 35.7
