Salvo
May 19, 2013Explorer
Thanks for the testing. The 0.1A gain compared to direct charge does seem quite low; especially when battery is at 12.5V. Is the controller's operating current high that it impacts your measurements? Perhaps using a panel that's greater than 100W will provide better results.
Sounds like there's a relay in your controller. It may be measuring open circuit voltage of the panel. Time to pull out the scope.
Sal
Sal
DSchmidt_2000 wrote:
I'm a bit disappointed to not have a much greater charging amps (only ~ 0.1A greater) given the delta between the battery and the panel is about 4V. Thinking that I may just be so low in power that I'm not in a high efficiency zone for this MPPT controller.
Putting my ear to the MPPT controller, I hear a regular 'ticking' noise. Will at some point drag out my digital scope and take some measurements to see what is going on.
