HiTech
May 19, 2013Explorer
DSchmidt_2000 wrote:
Did some testing today. (sorry for the data not being aligned- don't know how to post formatted text).
Setup:
45W 12V Solar Blvd panel with these specs
Maximum Power Voltage (Vmp): 18.0V
Maximum Power Current (Imp): 2.5A
Short Circuit Current (Isc): 2.73A
12V 35AH SLA battery which I depleted about 75% yesterday
Watt's-up meter in-line with the battery to measure current INTO the battery, battery voltage, and watts into battery.
DMM to measure the solar panel's voltage at the input of the MPPT controller.
I have Deans Connectors between the watts-up and the MPPT controller and between the solar panel and the MPPT controller so I can easily unplug things and make changes.
Testing: What I did was measure the current going into the battery if the MPPT controller was "in-the-loop", and then connected the solar panel directly to the battery. With the Deans connectors, I could do this switch around in seconds.
Here are the measurements in order they were taken (if no measurement listed - then I forgot to write it down)
With the MPPT "in-the-loop"
Solar V Batt A Batt V Watts
16.76 3.08 12.51
17.00 3.05 12.51
Solar direct to battery
2.89 12.50V 35.5
17.05 3.02 12.51 37.4
16.94 3.07 12.52 37.1
2.93 12.51 35.7
The battery voltage and watts were from the Watt's-up meter - it has uncertainty in its measurements hence the watts reported are not exactly that calculated just doing the math.
I'm a bit disappointed to not have a much greater charging amps (only ~ 0.1A greater) given the delta between the battery and the panel is about 4V. Thinking that I may just be so low in power that I'm not in a high efficiency zone for this MPPT controller.
Putting my ear to the MPPT controller, I hear a regular 'ticking' noise. Will at some point drag out my digital scope and take some measurements to see what is going on.
It would be worth running your battery down to 11 volts or so and running similar tests.
Jim
