DSchmidt_2000
May 19, 2013Explorer
HiTech wrote:
It would be worth running your battery down to 11 volts or so and running similar tests.
Jim
Yeah, was thinking about how to create an ideal load. Basically create a constant voltage load. If I built two of them then I could have one panel on the MPPT controller, the other on the PWM, set them out in the sun with a Watt's up on each and at the end of the day get the AH difference between the two.
