BFL13
May 12, 2015Explorer II
kje wrote:
How about the short absorb mode that doesn't stay on long at all. Can I do something with that?
Another thing, is it dangerous to disconnect the battery when the solar panel is connected to the controller?
Only thing you can do is make the Float voltage as high as your Vabs so the voltage stays the same. But the upper limit of Float is lower than the upper limit of Absorb. So on mine, I have 14.8 and 14.5 set.
It is not dangerous except to maybe the controller. Sequence is connect battery then array, disconnect array before disconnecting battery.
