JiminDenver's avatar
JiminDenver
Explorer II
Oct 16, 2012
Eco-worthy 20a MPPT controller
Last month I purchased the Eco-Worthy 20a MPPT controller from their website for $89 plus $24 shipping. Right now it says $102.50 and free shipping. You can see them on ebay with free shipping and if good can get one for as low as $80. That will be on a slow boat too as it took forever to get here.
Eco-worthy
u tube video I found on it
I set it up crudely this morning and wouldn't you guess, instantly had cloudy skies. Dark enough that there were no shadows and the controller was at best showing 2a. The panel is my Schott 230 watt, 36v panel rated up to 7.66a imp and 8.33a isc which I've confirmed before. It is just leaned against a fence and not tilted /rotated for best results
I started out using old batteries as a test, better to fry them than my trailers grp 27. They could be pulled down fast using a 350w inverter and a few lightbulbs, otherwise even in the shade the batteries voltage jumped and the controller went into float mode. In float and absorb modes it does PWM, only bulk mode does MPPT.
When the clouds cleared or as much as can be expected with the pollution, haze and smoke from the fires, I saw the amps jump to over 12a but only for a bit. They started dropping and went down to just over 5a in bulk mode. The controller is black , sitting in the direct sun and had gotten quite hot to the touch. It has a temp sensor in it so I am assuming it caused the cut in amps because even shading the box with my hand caused the amps to rise above 7 again. I shaded it and the amps went back up.
The best I saw was 13.1a in bulk mode. The controller has a PWM-MPPT comparison and at 13.1a it said the comparison was 8.67a in PWM. This is a calculation and too high for the rating. In absorb mode (PWM), in full sun it read in the 7a+ range which is close to the rated imp.
At that point the inverter was running 160w of bulbs and the batteries voltage was still climbing.
The next test will be to see if the set up will recharge the TTs grp 27 in a day after being brought down to 50%. If it can, I will be thrilled because even with furnace use we never see a 50% drop now and the Generator can be silent once again. Not bad for $200 invested.
If it can not, I'll have to decide if the controller is good enough and can be run in parallel like cruz does or send the controller back and run both of my panels off of a Rogue.
A few other tidbits.
as i mentioned, the temp sensor is in the case. I am going to see if I can't make it remote to the batteries somehow. That is a big advantage to the Rogue among other things but for a $250 savings I'll make sacrifices. I just need a charged battery for boondocking.
  • Hi HiTech,
    With free shipping it is cheaper than what Jim paid.
    HiTech wrote:
    I don't need MPPT, but I want to try it. Keep us up to date on how it works for you. If it goes back to $80 I will probably order one to play with. Can you force it into PWM mode to compare to MPPT?
    Jim
  • Hi Don
    There may be more than one version of this controller but I can't find any spec sheets on the web site. The sheet that came with mine says 300/600 so it would be my luck to pick the lower spec'd one.
    Jim
    It can't be forced into PWM mode while doing bulk charging, it will calculate the difference though. The lowest price with shipping I've seen is in a auction on ebay, otherwise the $102.50 with free shipping is a better deal than I got at $89 + $24 shipping. ( I did come close to bidding on one still in the 70's with 14 min left but I was still waiting on this one)
  • I don't need MPPT, but I want to try it. Keep us up to date on how it works for you. If it goes back to $80 I will probably order one to play with. Can you force it into PWM mode to compare to MPPT?
    Jim
  • JiminDenver wrote:
    Cruz. You are correct
    The voltage range is from 15,- 42v,and 300 watts max
    Do they give the watts for 12v and 24v? That came up in earlier threads re controller limits. ie, which is it for that 300w?
  • Cruz. You are correct
  • Wow...nice looking unit for $100!
    Am I correct in that it's max input voltage is 42 volts?
  • My 12v panel has an Isc of 8.2 at 25C but I often get 8.3 or 8.4 at high noon when it is cooler out, like 18C. (I know that panel temp is higher than ambient, but that is what I get.)
    My controller has the temp sensor built in too, but since it is also inside the trailer like the batteries are and close to them, it makes no diff --don't need a remote temp sensor.
