westend
May 12, 2015Explorer
JiminDenver wrote:Don't know how your Tristar is equipped for dip switches. On the MPPT-15 one dip switch needs to be changed to enable the serial connection.CA Traveler wrote:
Jim,
Wondering if the MSView problem can be related to your netbook. I'm using W7.
Does the #8 switch have to be on to use the either net or does it just keep you from changing settings from the computer?
I couldn't get past a certain point with the software, initially. I found that under the "Devices" menu, you can manually select the controller and assign it the correct com port. That enabled me to use all of the software, program set points, and get real time information.
