CA_Traveler
May 12, 2015Explorer III
JiminDenver wrote:#8 is just for making setting changes and you can access with it on or off.CA Traveler wrote:
Jim,
Wondering if the MSView problem can be related to your netbook. I'm using W7.
Does the #8 switch have to be on to use the either net or does it just keep you from changing settings from the computer?
Are you sure the 10BaseT Ethernet interface settings are absolutely correct in the computer? Maybe have someone else check. I have to disconnect the laptop from my normal wireless connection in order to access the controller - maybe a factor for you?
